[GRASS-user] combine & edit multiple text files
Slover, Kevin
kslover at Dewberry.com
Tue Aug 8 08:32:15 EDT 2006
Maning,
As David says, python or perl are used now for manipulating text
files. I have done several quick scripts for doing this with Perl
(thanks David for the python script, bout time I learn to use it). A
basic perl script would look like this (and note, my Perl is not great,
and am sure there are many other ways to do this) :
Explanation: Files.txt is a ls/dir listing of the wanted files to
combine. Then, the script reads in each file, stripping any sort of
header information from the columns, and outputting everything into one
file. Fairly simple, and a quick search on the web for file
manipulation using Perl will come up with probably a better explanation.
$in_file = "Files.txt";
$out_file = "outfile.txt";
open (INFILE, $in_file) || die "INFILE";
open (OUTFILE, ">$out_file") || die "OUTFILE";
@infiles = <INFILE>;
close(INFILE);
print OUTFILE "z,x,y\n";
foreach $in_files (@infiles)
open (INFILE1, $in_files) || die "Cannot open $in_files";
while (<INFILE1>)
chomp($_);
($x, $y, $z) = split ',',$_;
if ($x != x) {
print OUTFILE "$z,$x,$y\n"; }
close(INFILE1);
close(OUTFILE);
Kevin Slover
Coastal / GIS Specialist
2872 Woodcock Blvd Suite 230
Atlanta GA 30341
(P) 678-530-0022
(F) 678-530-0044
-----Original Message-----
[mailto:grassuser-bounces at grass.itc.it] On Behalf Of maning sambale
Sent: Tuesday, August 08, 2006 12:12 AM
To: grassuser at grass.itc.it
Subject: [GRASS-user] combine & edit multiple text files
Hi!
I have a number of ascii files downloaded from ASTR fire project from
the ESA Ionia showing monthly fire incidences from 1996-2006. I
intend to combine all these files, remove unwanted columns and get the
records from my current region/study area only. All records combined
is 929,155 records! My guess is I need to use the cat, cut, awk
commands.
Challenge: the files have different record formating
file 1 is like this (take note of the space as the delimiter):
Date Time Lat Lon NDVI Station
020201 032428.163 -38.379 -66.334 -.-- ESR
020201 032428.163 -38.375 -66.323 -.-- ESR
020201 032428.312 -38.378 -66.359 -.-- ESR
020201 032428.312 -38.374 -66.348 -.-- ESR
020201 032428.312 -38.371 -66.337 -.-- ESR
file 2 looks like this:
Date Orbit Time Lat Lon
20030101 4384 81704.016 19.364 -155.103
20030101 4384 81704.164 19.373 -155.105
20030101 4384 81704.164 19.375 -155.096
20030101 4385 100833.648 56.638 161.281
20030101 4386 130756.352 -20.340 134.099
I only need the columns for date, time, lat, lon
Here's what I did:
#combine all file (monthly)
cat 9904ESA01.FIRE 9905ESA01.FIRE 9906ESA01.FIRE 9907ESA01.FIRE
9908ESA01.FIRE ... > test
# cut only desired columns (1_4) delimeiter is spac ' '
cut -d' ' -f1 test > 1
cut -d' ' -f2 test > 2
cut -d' ' -f3 test > 3
cut -d' ' -f4 test > 4
# combine all columns
paste 1 2 3 4 > test5
example output:
021231 223941.761 11.035 -5.016 -.-- ESR
021231 224005.303 12.226 -6.243 -.-- ESR
20030101 4380 25934.057 -37.022 -69.589
20030101 4382 45951.090 33.005 -110.772
The problem is for the file example 1, lat and lon columns contain
spaces other than the delimiter example " -38.00" while another is
"120.00" In the file2 example, more spaces are there. I think I need
to process different file formats separately but how do I solve the
problem for spaces in the lat/lon columns?
One last question how do I get the records for my current region only?
north: 20:00:01.49976N
south: 5:00:01.499767N
west: 115:00:01.5012E
east: 130:00:01.501193E
I'm starting to understand awk (reading the gawk manual right now) but
may take a while to get do something magical.
Thanks!
Maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
|http://www.geocities.com/esambale/philbiodivmap/philbirds.html |
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
