[GRASS-user] howto make my srtm-dem jump the GIS gap
Rudolf Maurer
rudolf.maurer at googlemail.com
Wed Aug 9 05:51:18 EDT 2006
Dear List,
thank you for all those replies!
It looks like ArcGIS is not even able to read the file from inside
ArcCatalog?! My Sysadmin says the file on the Samba-Network-Share is
definitely OK.
Will try William and Macieks r.out.gdal suggestions, but did not do it yet.
When I export TIF I am losing the height data, right?
I spotted an online document on SRTM-Data which mentioned the direct import
of SRTM-Data using the Spatial Analyst extension.
Do I need this for importing the GRASS-made Grid-Files, too?
So long, going to keep you informed :-)
Rudy
2006/8/8, David Finlayson <david.p.finlayson at gmail.com>:
> I use r.our.arc frequenctly to transfer data between ArcGIS and GRASS.
> What exactly is the problem you are having?
> David
> On 8/7/06, Rudolf Maurer <rudolf.maurer at googlemail.com> wrote:
> > Dear List,
> my intention is to use my DEM from SRTM-data in GRASS in a well big, known
> GIS-System by E**i.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060809/d57caaa3/attachment.html
