[GRASS-user] alter table - sqlite
wqual
wolfgang.qual at gmx.net
Thu Aug 10 11:35:47 EDT 2006
Hi Martin,
I am using GRASS 6.1.CVS, and it works with the following command
v.db.addcol map=block_extrakt columns="neu INT"
I did not specify layer in this command (but when I tried layer=1, I also got
the same error message). However, you need not to specify the layer option,
as
"v.db.addcol adds one or more column(s) to the attribute table connected to a
given vector map. It automatically checks the connection for the specified
layer." (see g.manual v.db.addcol for example). Additionally, the "layer"-tag
needs to be written before the columns-tag.
I hope that this might help you.
Am Donnerstag 10 August 2006 pH:07:17 nachmittags/abends schrieb Martin
Rutzinger:
> hi list!
> i'm working with sqlite and i want to add a column to the table of
> 'vector1'. i tried several possibilities (v.db.addcol, db.execute; double,
> real,...) but i got always the same error:
> e.g.
> v.db.addcol map=vector1 columns="area_size REAL" layer=1
> DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> near "ALTER": syntax error
> FEHLER: Error while executing: "ALTER TABLE vector1 ADD COLUMN
> area_size REAL
> ERROR: Cannot continue (problem adding column).
> e.g.
> echo "ALTER TABLE vector1 ADD COLUMN area_size DOUBLE PRECISION" |
> db.execute
> but: if i use the sqlitebrowser and execute the statement in the 'execute
> sql tab' like this, it works(!):
> however, i need a solution adding a column using shell scripting & sqlite.
> what do i wrong? has anybody had a similar problem?
> thanks,
> martin
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
