[GRASS-user] Re: voronoi for polygons
Martin Rutzinger
Martin.Rutzinger at uibk.ac.at
Thu Aug 10 13:13:11 EDT 2006
hi martin w.!
these steps...
- convert the selected polygons to raster (v.to.rast)
- switch null() values to 1 and pixels with values to null() (r.mapcalc)
- thin raster (r.thin) several iterations
- convert thinned raster to vector and make polygons (r.to.vect,...)
...derive voronoi polygons from your 'input polygons' directly so that you need
not to "group all voronoi polygons which belong to points of one polygon"
see:
http://geo4.uibk.ac.at/users/rutzinger/download/topology5_grass_fire_poly.jpg
if you have done that, you have to assign the cat-values of your 'input polygons
to the 'voronoi polygons'. i think this should be possible with v.distance, but
i'm not sure.
hope this helps
martin r.
Zitat von Martin Wegmann <wegmann at biozentrum.uni-wuerzburg.de>:
> Hello Martin,
> On Wednesday 09 August 2006 17:22, Martin Rutzinger wrote:
> > i'm not sure what is wrong with v.select, but i can show a second approach
> > how to derive voronoi polygons (restriction: doesn't work for adjacent
> > polygons):
> thanks for your help, I tried your approach, but having polygons as input
> (not
> adjacent ones) and using them as base for voronoi polygons between polygons,
> this approach does not work for me or I misunderstood you:
> ok
> it works for my base polygons, because they are not adjacent, but not for my
> voronoi polygons. I have no null() values because my voronoi polygons are
> adjacent and cover the whole location
> that does not work due to the previous problem, but how do you distinguish
> between voronoi polygons belonging to the same base polygon and vornoi
> polygons belonging to the base polygons in the neighbourhood? Extracting the
> border between two voronoi polygon groups (for 2 base polygons) would be
> interesting, but I have no idea how to tell GRASS which line that is.
> regards, Martin
> > this works for me
> > /martin
> > Hello,
> > I want to calculate voronoi areas for polygons, but I am stuck in
> > the "query-part".
> > using spearfish data I did:
> > v.extract input=fields at PERMANENT output=fields_extract list=41,36,46,21
> > v.to.points input=fields_extract output=fields_extract_points type=boundary
> > v.voronoi input=fields_extract_points output=fields_extract_points_voron
> > now I wanted to
> > - group all voronoi polygons which belong to points of one polygon (GIS
> > query overlap)
> > - calculate area of merged voronoi polygons and assign them to each
> > original polygon
> > but:
> > v.select operator=overlap gives:
> > v.select binput=fields_extract_points_voron_clean
> > ainput=fields_extract_clean atype=area btype=area output=test
> > operator=overlap
> > Processing ainput areas ...
> > 100%
> > Writing attributes ...
> > Layer 1
> > v.select complete.
> > Building topology ...
> > 0 primitives registered
> > 0 areas built
> > 0 isles built
> > Attaching islands:
> > Attaching centroids: Topology was built.
> > Number of nodes : 0
> > Number of primitives: 0
> > Number of points : 0
> > Number of lines : 0
> > Number of boundaries: 0
> > Number of centroids : 0
> > Number of areas : 0
> > Number of isles : 0
> > anything wrong with the command?
> > I did it as well without b/atype=area but same result.
> > The problem how to calculate areas is not yet tackled ,-)
> > I appreciate any hint, Martin
