[GRASS-user] integration of sample.c algorithms into r.resample
Glynn Clements
glynn at gclements.plus.com
Fri Aug 11 23:45:00 EDT 2006
Dylan Beaudette wrote:
> > > 1. the output is not quite correct when the region is not aligned to the
> > > input raster, including edge effects
> > Actually r.bilinear is all screwed:
> > http://intevation.de/rt/webrt?serial_num=2790
> > There are two issues. Please see my most recent posts and Urs Gruber's
> > post dated Tue, Feb 14 2006 17:16:21.
> Hehe - I was waiting for you to chime in with that bug ! Indeed. Looking
> through r.bilinear there are a lot of (data + 0.5) operations that I don't
> quite understand -- my limited ability or small errors: not completely sure.
> > It would be great to have r.bilinear fixed and all algorithms merged
> > into one command. Good luck!
> Sure. Well - with Glynn's help on the rowio library -- I am hoping on fixing
> sample.c so that it uses row caching and verify that NULL support is
> correctly done. Then, it would be a matter of calling the sample.c algorithms
> at each new grid cell.
> I would like to get this done, but it may take a little while. Any help would
> be great.
I've attached a modified version of r.bilinear which does
nearest-neighbour, bilinear and bicubic interpolation. It's only been
lightly tested, but the case where the source and destination regions
match (exact copy) has been tested. It could use some testing at more
extreme scale factors.
It would be possible to speed it up a bit, at the expense of
simplicity, by caching the horizontal interpolates for each row.
However, even in its present form, it's still likely to be a lot
faster than using the functions in sample.c.
#include <stdlib.h>
#include <math.h>
#include <grass/gis.h>
#include <grass/glocale.h>
static int neighbors;
static DCELL *bufs[4];
static int cur_row;
static void read_rows(int infile, int row)
int end_row = cur_row + neighbors;
int first_row = row;
int last_row = row + neighbors;
int offset = first_row - cur_row;
int keep = end_row - first_row;
DCELL *tmp;
int i;
if (end_row >= last_row)
return;
if (keep > 0 && offset > 0)
for (i = 0; i < keep; i++)
DCELL *tmp = bufs[i];
bufs[i] = bufs[i + offset];
bufs[i + offset] = tmp;
if (keep < 0)
keep = 0;
for (i = keep; i < neighbors; i++)
G_get_d_raster_row(infile, bufs[i], first_row + i);
cur_row = first_row;
int main( int argc, char *argv[])
struct GModule *module;
struct Option *rastin, *rastout, *method;
char *inmap;
int infile, outfile;
DCELL *outbuf;
int row, col;
struct Cell_head dst_w, src_w;
G_gisinit(argv[0]);
module = G_define_module();
module->description =
_("Bilinear interpolation utility for raster map layers.");
rastin = G_define_standard_option(G_OPT_R_INPUT);
rastout = G_define_standard_option(G_OPT_R_OUTPUT);
method = G_define_option();
method->key = "method";
method->type = TYPE_STRING;
method->required = NO;
method->description = _("Interpolation method");
method->options = "nearest,bilinear,bicubic";
method->answer = "bilinear";
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
if (G_strcasecmp(method->answer, "nearest") == 0)
neighbors = 1;
else if (G_strcasecmp(method->answer, "bilinear") == 0)
neighbors = 2;
else if (G_strcasecmp(method->answer, "bicubic") == 0)
neighbors = 4;
else
G_fatal_error(_("Invalid method: %s"), method->answer);
G_get_set_window(&dst_w);
inmap = G_find_file2("cell", rastin->answer, "");
if (!inmap)
G_fatal_error(_("Couldn't find raster file %s"), rastin->answer);
/* set window to old map */
G_get_cellhd(rastin->answer, inmap, &src_w);
/* enlarge window */
src_w.south -= src_w.ns_res * (neighbors / 2);
src_w.north += src_w.ns_res * (neighbors / 2);
src_w.west -= src_w.ew_res * (neighbors / 2);
src_w.east += src_w.ew_res * (neighbors / 2);
src_w.rows += 2 * (neighbors / 2);
src_w.cols += 2 * (neighbors / 2);
G_set_window(&src_w);
/* allocate buffers for input rows */
for (row = 0; row < neighbors; row++)
bufs[row] = G_allocate_d_raster_buf();
cur_row = -100;
/* open old map */
infile = G_open_cell_old(rastin->answer, inmap);
if (infile < 0)
G_fatal_error(_("Not able to open cellfile for [%s]"), rastin->answer);
/* reset window to current region */
G_set_window(&dst_w);
outbuf = G_allocate_d_raster_buf();
/* open new map */
outfile = G_open_raster_new(rastout->answer, DCELL_TYPE);
if (outfile < 0)
G_fatal_error(_("Not able to open cellfile for [%s]"), rastout->answer);
G_suppress_warnings(1);
/* otherwise get complaints about window changes */
switch (neighbors)
case 1: /* nearest */
for (row = 0; row < dst_w.rows; row++)
double north = G_row_to_northing(row + 0.5, &dst_w);
double maprow_f = G_northing_to_row(north, &src_w) - 0.5;
int maprow0 = (int) floor(maprow_f + 0.5);
G_percent(row, dst_w.rows, 2);
read_rows(infile, maprow0);
for (col = 0; col < dst_w.cols; col++)
double east = G_col_to_easting(col + 0.5, &dst_w);
double mapcol_f = G_easting_to_col(east, &src_w) - 0.5;
int mapcol0 = (int) floor(mapcol_f + 0.5);
double c = bufs[0][mapcol0];
if (G_is_d_null_value(&c))
G_set_d_null_value(&outbuf[col], 1);
else
outbuf[col] = c;
G_put_d_raster_row(outfile, outbuf);
break;
case 2: /* bilinear */
int maprow0 = (int) floor(maprow_f);
int maprow1 = maprow0 + 1;
double v = maprow_f - maprow0;
int mapcol0 = (int) floor(mapcol_f);
int mapcol1 = mapcol0 + 1;
double u = mapcol_f - mapcol0;
double c00 = bufs[0][mapcol0];
double c01 = bufs[0][mapcol1];
double c10 = bufs[1][mapcol0];
double c11 = bufs[1][mapcol1];
if (G_is_d_null_value(&c00) ||
G_is_d_null_value(&c01) ||
G_is_d_null_value(&c10) ||
G_is_d_null_value(&c11))
else
DCELL c0 = u * (c01 - c00) + c00;
DCELL c1 = u * (c11 - c10) + c10;
DCELL c = v * (c1 - c0 ) + c0 ;
outbuf[col] = c;
break;
case 4: /* bicubic */
int maprow1 = (int) floor(maprow_f);
int maprow0 = maprow1 - 1;
int maprow2 = maprow1 + 1;
int maprow3 = maprow1 + 2;
double v = maprow_f - maprow1;
int mapcol1 = (int) floor(mapcol_f);
int mapcol0 = mapcol1 - 1;
int mapcol2 = mapcol1 + 1;
int mapcol3 = mapcol1 + 2;
double u = mapcol_f - mapcol1;
double c02 = bufs[0][mapcol2];
double c03 = bufs[0][mapcol3];
double c12 = bufs[1][mapcol2];
double c13 = bufs[1][mapcol3];
double c20 = bufs[2][mapcol0];
double c21 = bufs[2][mapcol1];
double c22 = bufs[2][mapcol2];
double c23 = bufs[2][mapcol3];
double c30 = bufs[3][mapcol0];
double c31 = bufs[3][mapcol1];
double c32 = bufs[3][mapcol2];
double c33 = bufs[3][mapcol3];
G_is_d_null_value(&c02) ||
G_is_d_null_value(&c03) ||
G_is_d_null_value(&c11) ||
G_is_d_null_value(&c12) ||
G_is_d_null_value(&c13) ||
G_is_d_null_value(&c20) ||
G_is_d_null_value(&c21) ||
G_is_d_null_value(&c22) ||
G_is_d_null_value(&c23) ||
G_is_d_null_value(&c30) ||
G_is_d_null_value(&c31) ||
G_is_d_null_value(&c32) ||
G_is_d_null_value(&c33))
else
DCELL c0 = (u * (u * (u * (c03 - c02 + c01 - c00) + (c02 - c03 - 2 * c01 + 2 * c00)) + (c02 - c00)) + c01);
DCELL c1 = (u * (u * (u * (c13 - c12 + c11 - c10) + (c12 - c13 - 2 * c11 + 2 * c10)) + (c12 - c10)) + c11);
DCELL c2 = (u * (u * (u * (c23 - c22 + c21 - c20) + (c22 - c23 - 2 * c21 + 2 * c20)) + (c22 - c20)) + c21);
DCELL c3 = (u * (u * (u * (c33 - c32 + c31 - c30) + (c32 - c33 - 2 * c31 + 2 * c30)) + (c32 - c30)) + c31);
DCELL c = (v * (v * (v * (c3 - c2 + c1 - c0 ) + (c2 - c3 - 2 * c1 + 2 * c0 )) + (c2 - c0 )) + c1 );
outbuf[col] = c;
break;
G_percent(dst_w.rows, dst_w.rows, 2);
G_close_cell(infile);
G_close_cell(outfile);
return(EXIT_SUCCESS);
