[GRASS-user] Grass 6.1 - error installing rpm
Markus Neteler
neteler at itc.it
Mon Aug 14 05:14:16 EDT 2006
On Mon, Aug 14, 2006 at 11:07:02AM +0200, Markus Neteler wrote:
> On Sun, Aug 13, 2006 at 08:49:53PM +0200, Helmut Kudrnovsky wrote:
> > hi grass-friends,
> > i?ve downloaded the rpm?s for the new release of grass 6.1.
> > the install of the rpm?s for proj4, geos, and gdal was o.k.
> > installing the GRASS 6.1-rpm?s i got following message:
> > "Installing grass-6.1.0-1suse10.0.i586 [Local packages]. There are no installable providers of libmysqlclient.so.14 for grass-6.1.0-1suse10.0.i586 [Local packages]."
> > in the spec-file i saw that the rpm for grass was build with the mysql-option.
> > any hints for solving the rpm-dependency-problem?
> > suse 10.1. on my computer.
> > thanks a lot for the hard work for GRASS 6.1.
> > greetings
> Hi helli,
> apparently I forgot to define
> Requires: mysql
> in the spec file. Can you install the mysql RPM and try again?
> Then it should hopefully work.
> You may contact me through personal email to work that out.
Checking again, it seems that
mysql-shared
would be sufficient. I cannot login to our Suse PC right now, so
I cannot check.
Markus
