[GRASS-user] integration of sample.c algorithms into r.resample
Maciej Sieczka
tutey at o2.pl
Mon Aug 14 06:16:07 EDT 2006
Glynn Clements napisa?(a):
> Dylan Beaudette wrote:
>> How about this:
>> 1. keep r.resample and update the documentation accordinly.
>> 2. toss r.bilinear, possibly leave a note somewhere in the docs
> Or replace it with a script which calls "r.interpolate method=bilinear".
>> 3. create a new module 'r.resample.3' (?) for the three methods that it would
>> do? or 'r.interpolate' (?)
> I prefer r.interpolate.
If I may not agree - *inter* suggests this module will be able to fill
null gaps. This is not the case. It will even make the opposite - make
the gaps bigger in the output for method= bilinear and bicubic, if nulls
are present in the input.
This module is for re-sampling and r.resample is the only good name I
can think of currently.
IMHO: drop r.bilinear, replace r.resample. To provide compatibility with
old r.resample (that performed nearest neighbor only) set the default
method=nearest. This will keep things simple and backward compatible.
If it is necessary to mantain r.bilinear compatibilty, make it a script
that calls r.resample method=bilinear.
What do you think?
Maciek
