[GRASS-user] integration of sample.c algorithms into r.resample
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Aug 17 13:19:28 EDT 2006
On Thursday 17 August 2006 09:37, Paul Kelly wrote:
> On Thu, 17 Aug 2006, Dylan Beaudette wrote:
> > On 8/17/06, Paul Kelly <paul-grass at stjohnspoint.co.uk> wrote:
> >> To throw in another suggestion, how about r.resamp.interp? This it would
> >> mean it would be adjacent in the manuals to the other resampling modules
> >> (r.resample and r.resamp.rst) for anyone looking for them, and might
> >> also imply that r.resample (the only one with the full word in its name)
> >> was kind of a default, basic resampler whilst r.resamp.interp and
> >> r.resamp.rst used more advanced and/or interesting resampling methods.
> > That sounds good to me.
> Well I would commit it to CVS if it's OK. I briefly edited the r.bilinear
> man page to create a rough manpage for r.resamp.interp (see below): are
> there any glaring errors?
> Paul
> r.resamp.interp(1) Grass User's Manual r.resamp.interp(1)
> NAME
> r.resamp.interp - Resamples raster map layers using
> interpolation.
> SYNOPSIS
> r.resamp.interp
> r.resamp.interp help
> r.resamp.interp input=name output=name [method=string]
> [--overwrite]
> Flags:
> --overwrite
> Parameters:
> input=name
> Name of input raster map
> output=name
> Name for output raster map
> method=string
> Interpolation method Options: nearest,bilinear,bicubic
> Default: bilinear
> DESCRIPTION
> r.resamp.interp fills a grid cell (raster) matrix with
> interpolated values generated from a set of input layer
> data points. A choice of three interpolation methods is
> available; each uses the weighted values of a different
> number of adjacent cells in the input map to determine the
> value of each cell in the output map as follows:
> nearest neighbour (1 cell)
> bilinear (4 cells)
> bicubic (12 cells)
> If there is a current working mask, it applies to the out
> put raster file. Only those cells falling within the mask
> will be assigned interpolated values. The procedure for
> selection of input data will consider all input data rele
> vant to interpolating values at the cell centers of the
> current geographic region, ignoring the curent mask. Note
> that for bilinear and bicubic interpolation, cells of the
> output raster that cannot be bounded by the appropriate
> number of input cell centers are set to null.
> NOTES
> For longitude-latitude databases, the interpolation algo
> rithm is based on degree fractions, not on the absolute
> distances between cell centers. Any attempt to implement
> the latter would violate the integrity of the interpola
> tion method.
> SEE ALSO
> g.region, r.resample, r.resamp.rst
> AUTHOR
> Glynn Clements
> Last changed: $Date: 2003/04/30 15:17:25 $
> Full index
> GRASS 6.3.cvs r.resamp.interp(1)
That looks good for now. Thanks!
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
