[GRASS-user] Landsat image tiffs
Zenon Panoussis
oracle at provocation.net
Fri Aug 18 18:55:53 EDT 2006
Dylan Beaudette wrote:
>> That's it. mapserver is happy, debug shows no errors, there's only
>> one little problem: the image doesn't show on the map...
> I have had some similar problems wrt. exporting landsat data from GRASS ->
> mapsever. here is my approach:
> #export tiled landsat-shade tiles:
> for x in `seq 2 1 49`; do g.region rast=ca_landsat_shade_$x; r.out.tiff -t
> in=ca_landsat_shade_$x out=ca_landsat_shade_$x.tif; done
> # re-create geotiffs with gdal_translate (fix bug in tiffs created with
> r.out.tiff)
> for x in `ls *.tif`; do gdal_translate -a_srs '+proj=aea +x_0=0.0 +y_0=0.0
> +lon_0=-96.0 +lat_0=40.0 +lat_1=20.0 +lat_2=60.0 +datum=NAD83' $x ../new/$x ;
> done
Hmm. You had to set the projection manually? And there's no -ot
to gdal_translate, so it used Byte in and Byte out.
Looking at the output of my r.out.tif:
gdalinfo 007068_15meROT.tif
Driver: GTiff/GeoTIFF
Size is 15535, 14461
Coordinate System is `'
Origin = (243347.250000,-1176408.750000)
Pixel Size = (14.25000000,-14.25000000)
Corner Coordinates:
Upper Left ( 243347.250,-1176408.750)
Lower Left ( 243347.250,-1382478.000)
Upper Right ( 464721.000,-1176408.750)
Lower Right ( 464721.000,-1382478.000)
Center ( 354034.125,-1279443.375)
Band 1 Block=128x128 Type=Byte, ColorInterp=Red
Band 2 Block=128x128 Type=Byte, ColorInterp=Green
Band 3 Block=128x128 Type=Byte, ColorInterp=Blue
No projection. Then perhaps my suspicion that I'm using the wrong
data type is wrong, it could be the missing projection that's causing
mapserver to ignore the image.
> terse i know, but hopefully helpful.
It is already :) I only need to figure the values of my -a_srs so
I can test it. And mapserver output your ../new/$x without problems?
Z
