[GRASS-user] gdal floating point exception
Zenon Panoussis
oracle at provocation.net
Tue Aug 22 16:12:44 EDT 2006
jarekj at amu.edu.pl wrote:
> I has consulted it with linux guru's as systemic problem they sed that
> gdal is very rare library (in Poland grass is really used by no more
> than 50 people) and sugesst to consult with user of that libraries.
Libraries usually don't care in which country they work, unless some
odd locale settings are messing things up. LC_NUMERIC != C seems to
cause problems with gdal. You could try exporting all the LC_XYZ
variables to non-localised values (or simply an out-of-the-box
US-English common distro installation) and see what happens.
Z
