AW: AW: [GRASS-user] v.in.ascii error: G_realloc
Maciej Sieczka
tutey at o2.pl
Thu Aug 24 02:58:17 EDT 2006
Praktikant/in2 ARP napisa?(a):
> I send you the small text file which does work with nnbathy but doesn't work with
> r.surf.nnbathy after importing in GRASS with r.in.xyz
> Maybe something is wrong with the text file. Or I make something wrong when
> importing the xyz file in Grass.
Thanks for the sample. To reproduce your setup I also need the exact
r.in.xyz command you used to import the file as well as the region
settings where r.surf.nnbathy fails (g.region -g output).
I might be able to look into this next week.
Maciek
