[GRASS-user] v.patch and layers
Markus Neteler
neteler at itc.it
Thu Aug 24 03:13:43 EDT 2006
Dear Aldo,
in GRASS 6.1.0 v.patch was improved
http://grass.itc.it/announces/announce_grass610.html
-> *v.patch*: attribute transfer, if table structures are identical
Probably this solves the problem for you (i.e. that you won't
even have to use v.db.connect any more).
You can download various RPMs from the download page.
Best regards
Markus
Aldo Clerici wrote on 08/23/2006 11:30 AM:
> Dear GRASSusers,
> I am having a problem (with GRASS 6.0.2).
> I have 2 vectors (map1 and map2)containing points. Each of them has a table
> with attributes.
> I created a new file (map3) by:
> v.patch in=map1,map2 out=map3
> And
> v.db.connect map3 table=map1 layer=1 key=cat
> v.db.connect map3 table=map2 layer=2 key=cat
> The connections are OK as shown by:
> v.db.connect -p map3
> But when I enter v.digit to modify some attribute all the points are
> assigned to layer 1. Layer 2 with the map2 attribute table is ignored. Is
> there a way to access and modify attributes of all layers in a patched map?
> I had the same problem with d.what.vect.
> Many thanks in advance
> Aldo Clerici
