[GRASS-user] RE: [GRASSLIST:1174] Working with very large dat
asets
David Finlayson
david.p.finlayson at gmail.com
Thu Aug 24 16:19:17 EDT 2006
I assume that you were in a linux environment on your ship's network?
Our aquisition and navigation software run only on Windows machines.
Sidescan is processed on Windows, RTK GPS is on Windows, I have some
flexibility on bathy processing but you can see the pattern...
I just updated the cygwin version of grass 6.1.cvs and it doesn't have
r.in.xyz.
Cygwin grass is kind-of a mixed bag anyway...
How much work is involved compiling Grass on cygwin? I've only compiled it
on Linux.
On 8/24/06, Patton, Eric <epatton at nrcan.gc.ca> wrote:
> Just to chime in on Hamish' r.in.xyz - I just got back from a field survey
> of the Bay of Fundy where 56GB of swath sonar (Simrad EM1002) was
> collected.
> After exporting each survey day from Caris HIPS as xyz, I've used r.in.xyz+
> r.patch to import the entire 56GB into Grass with no problems. I've always
> felt that r.in.xyz runs very quickly given the size of each xyz dataset.
> ~ Eric.
> -----Original Message-----
> From: grassuser-bounces at grass.itc.it
> To: Jonathan Greenberg; David Finlayson
> Cc: grassuser at grass.itc.it; Helena Mitasova; Andrew at grass.itc.it; Danner
> Sent: 8/24/2006 2:50 AM
> Subject: Re: [GRASS-user] RE: [GRASSLIST:1174] Working with very large
> datasets
> David Finlayson wrote:
> > I am working with an interferometric sidescan SONAR system that
> > produces about 2 Gb of elevation and amplitude data per hour. Our raw
> > data density could support resolutions up to 0.1 m, but we currently
> > can't handle the data volume at that resolution so we decimate down to
> > 1 m via a variety of filters. Still, even at 1 m resolution, our
> > datasets run into the hundreds of Mb and most current software just
> > doesn't handle the data volumes well.
> > Any thoughts on processing and working with these data volumes (LIDAR
> > folks)? I have struggled to provide a good product to our researchers
> > using both proprietary (Fledermaus, ArcGIS) and non-proprietary (GMT,
> > GRASS, my own scripts) post-processing software. Nothing is working
> > very well. The proprietary stuff seems easier at first, but becomes
> > difficult to automate. The non-proprietary stuff is easy to automate,
> > but often can't handle the data volumes without first down sampling
> > the data density (GMT does pretty well if you stick to line-by-line
> > processing, but that doesn't always work).
> > Just curious what work flows/software others are using. In particular,
> > I'd love to keep the whole process FOSS if possible. I don't trust
> > black boxes.
David Finlayson
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060824/2016a14d/attachment.html
