[GRASS-user] [GRASSLIST:1178] how to use cloud cover with r.sun?
Vishal Mehta
vishalm1975 at gmail.com
Fri Aug 25 07:25:34 EDT 2006
Thanks everyone,
a few thoughts-
1. Neither the r.sun manual, nor the r.slope.aspect manual, states that the
x,y and elevation units should be the same. In fact both manuals say the
elevation should be in meters! r.sun talks about how if the maps are
projected then it does'nt matter- but it does not talk of use with lat-long
system(nor does r.slope.aspect).
do these manuals then just assume that we are using a projection where the
x,y are in meters??
2. Hamish and Markus are right - my study area covers several utm zones.
3. At this point i'll try the dem, slope, aspect and r.sun in Lambert
conformal conic projection with everest datum;
or if that does not work, i'll try Hamish' idea of rescaling the elevation
to degrees.
I still cant get over the idea that GRASS cant handle correctly slope
generation in lat-long coordinates with elevation in meters!
thanks again,
vishal
On 8/25/06, Hamish <hamish_nospam at yahoo.com > wrote:
> > But is it really possible that the r.sun module (i'm using Grass 6.0.1
> > on Ubuntu Breezy) would treat elevation in degrees??
> Yes, it is possible. Maybe even likely.
> > And can you please tell me where the 1852*60 comes from?
> There are 1852 meters in a nautical mile. There are 60 nautical miles in
> a degree of latitude. elev_in_meters / (1850.0 * 60) = elevation in deg
> The width of a deg longitude is equal to width_lat*cos(lat).
> If rescaling the elevation into degress be sure to /(1852.0*60). This
> ensures that the result will be a floating point value (as opposed to
> /(1852*60) ).
> > I guess i would have to creat a new location in UTM coordinates and
> > then do the projecting back and forth you suggest..
> I think this is the saner solution, but I expect that a single UTM zone
> is not an appropriate projection for working with an area the size of
> India.
> Markus wrote:
> > This should be a projection covering the entire subcontinent
> > in a reasonable way - what are the official projection(s) for
> > that area?
> If you have problems finding one, you might ask for help on the PROJ.4
> mailing list.
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060825/1ed90371/attachment.html
