[GRASS-user] Error on latest gis.m
Michael O'Donovan maodonovan at gmail.com
Fri Aug 25 13:34:10 EDT 2006
When I type "gis.m&" I get the  error listed below. I am using the latest cvs
on AMD 64 machine (Suse 9.3). An ideas as to how to fix this?
Error in startup script: syntax error in expression "int(abs(25:54:11.378871S
- 26:27:14.684457S)/0:00:03.599466)": missing close parenthesis at end of
function call
    while executing
"expr int(abs([lindex $region 0] - [lindex $region 1])/[lindex $region 4])"
    (procedure "MapCanvas::currentzoom" line 31)
    invoked from within
"MapCanvas::currentzoom $mon"
    (procedure "MapCanvas::coordconv" line 24)
    invoked from within
"MapCanvas::coordconv $mon"
    (procedure "MapCanvas::create" line 72)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 74)
    invoked from within
"Gm::create"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.3.cvs/etc/gm/gm.tcl" line 528)
