[GRASS-user] [bug #3041] nviz max resolution ppm image dump
Tue Aug 29 02:06:08 EDT 2006
William Hargrove wrote:
> >>My nviz dies with a segfault when I try to dump an image as maximum
> >>resolution ppm.
> >>I have this same problem with grass 6.1 under FC 5, and under grass
> >>5.4 under FC 4.
> >>I can dump the other formats just fine.
> >>The map products look great on the screen, but aren't much use if I
> >>can't get them into a high-res image file.
> >>Does anyone have any advice on this problem?
Hamish wrote:
> >what's the date on the 6.1? 6.1.0 or 6.1-cvs? This was an old known
> >problem on 64bit &/or big endian (Mac G5), I had thought that it was
> >fixed by Glynn & crew some months ago.
I guess it is this bug after all:
> > http://intevation.de/rt/webrt?serial_num=3041
> This is 6.1.0 built from source, running under 64-bit FC 5.
> Here is what happens when I try to dump a max-res ppm:
> recalculating normals...
> Diagnostic: invalid command name "Nviz_animation_save" --  Save
> procedure for panel animation may not be defined
> Diagnostic: invalid command name "Nviz_kanimator_save" --  Save
> procedure for panel kanimator may not be defined
> Diagnostic: invalid command name "Nviz_query_save" --  Save procedure
> for panel query may not be defined
> Diagnostic: invalid command name "Nviz_sdiff_save" --  Save procedure
> for panel sdiff may not be defined
> Diagnostic: invalid command name "Nviz_label_save" --  Save procedure
> for panel label may not be defined
> Diagnostic: invalid command name "Nviz_scale_save" --  Save procedure
> for panel scale may not be defined
> Diagnostic: invalid command name "Nviz_pos_save" --  Save procedure
> for  panel pos may not be defined
> Diagnostic: invalid command name "Nviz_resize_save" --  Save procedure
> for panel resize may not be defined
> Diagnostic: invalid command name "Nviz_pick_save" --  Save procedure
> for  panel pick may not be defined
> Diagnostic: invalid command name "Nviz_highlight_save" --  Save
> procedure for panel highlight may not be defined
> Creating PBuffer Using GLX 1.3
> Final Assembled Image will be 1 x 1
> Writing Tile 1 of 1
> Assembling Tiles
> GLX -- destroy pbuffer
> ./donviz: line 2: 10088 Segmentation fault      nviz
> elevation=elev48.new color=neon2.25
> vector=states100,neondomains_states
> Any ideas?
I get a segfault too:   (32bit P4, 2gig RAM, Debian/stable)
Speafish with nviz window made to be large:
G63> nviz elevation.10m
Loading Data
Update elev null mask
Loading Data
translating colors from fp
r200_makeX86Normal3fv/197 CVAL 0 OFFSET 14 VAL 8260df0
r200_makeX86Normal3fv/198 CVAL 4 OFFSET 20 VAL 8260df4
r200_makeX86Normal3fv/199 CVAL 8 OFFSET 25 VAL 8260df8
r200_makeX86Normal3fv done
% recalculating normals...
Create PixMap Using GLX 1.1
Final Assembled Image will be 1935 x 2048
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
MALLOC Failed
Segmentation fault
(hard to replicate)
The "MALLOC Failed" message comes from lib/ogsf/gsd_prim.c
int gsd_writeView(unsigned char **pixbuf, unsigned int xsize,
                  unsigned int ysize)
    /* Malloc Buffer for image */
    *pixbuf = malloc(xsize * ysize * 4);
    if (!*pixbuf) {
        fprintf(stderr, "MALLOC Failed\n");
        return (0);
    /* Read image buffer */
    glReadBuffer(GL_FRONT);
    /* Read Pixels into Buffer */
    glReadPixels(0, 0, xsize, ysize, GL_RGBA, GL_UNSIGNED_BYTE, *pixbuf);
    return (1);
with window left at starting size:  [note larger "Final Assembled Size"]
Loading Data
Loading Data
r200_makeX86Normal3fv/197 CVAL 0 OFFSET 14 VAL 82613f8
r200_makeX86Normal3fv/198 CVAL 4 OFFSET 20 VAL 82613fc
r200_makeX86Normal3fv/199 CVAL 8 OFFSET 25 VAL 8261400
% Creating PBuffer Using GLX 1.3
Final Assembled Image will be 2048 x 2048
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
Writing Tile 4 of 9
Writing Tile 5 of 9
Writing Tile 6 of 9
Writing Tile 7 of 9
Writing Tile 8 of 9
Writing Tile 9 of 9
Assembling Tiles
pnmcat: Zero byte allocation
pnmcat failed to create assembled image
Check that pnmcat is installed and path is set
pnmcat: EOF / read error reading magic number
pnmcat failed to create assembled images
Destroy Pixmap and GLXPixmap
no segfault, NVIZ keeps running, these files are left behind:
(easy to replicate)
      0 Aug 29 17:24 spearNVhi2.ppm
3145745 Aug 29 17:24 spearNVhi2_1_1.ppm
3145745 Aug 29 17:24 spearNVhi2_1_2.ppm
     14 Aug 29 17:24 spearNVhi2_1_3.ppm
3145745 Aug 29 17:24 spearNVhi2_2_1.ppm
3145745 Aug 29 17:24 spearNVhi2_2_2.ppm
     14 Aug 29 17:24 spearNVhi2_2_3.ppm
     14 Aug 29 17:24 spearNVhi2_3_1.ppm
     14 Aug 29 17:24 spearNVhi2_3_2.ppm
     11 Aug 29 17:24 spearNVhi2_3_3.ppm
      0 Aug 29 17:24 spearNVhi2tmp1.ppm
      0 Aug 29 17:24 spearNVhi2tmp2.ppm
      0 Aug 29 17:24 spearNVhi2tmp3.ppm
      0 Aug 29 17:30 spearNVhi3.ppm.ppm
assembly of rows then full image fail as partials are not valid images
(14 byte ones). Images with data assemble, but contain random x-window
buffer weirdness: multi-virtual-desktop collages.
Summary: the partial tiles are broken.
I haven't tried it with just one workspace.
minimizing the NVIZ window (before clicking "ok" for the output
filename) gives the same result.
at the end of the bug report Glynn offers a reason, but I have no idea
where to go from there. Dumb debugging effort: I still get the broken
result if I comment out "Nset_cancel_func update" in
  visualization/nviz/scripts/nviz2.2_script
and rebuild nviz.
Hamish
