[GRASS-user] [bug #3041] nviz max resolution ppm image dump
Glynn Clements
glynn at gclements.plus.com
Tue Aug 29 21:42:05 EDT 2006
Hamish wrote:
> > Note that setting the environment variables:
> > GRASS_NO_GLX_PBUFFERS
> > GRASS_NO_GLX_PIXMAPS
> > will disable use of these features, in case of problems with your
> > OpenGL setup (libraries or X server). Their values don't matter, only
> > whether or not they are set.
> These should be added to lib/init/variables.html
I'll do that.
> Setting those make no difference to this bug however:
> #with GLX
> G63 > nviz elevation.10m
> % Creating PBuffer Using GLX 1.3
> Create PixMap Using GLX 1.1
> Final Assembled Image will be 1929 x 2048
> Assembling Tiles
> pnmcat: EOF / read error reading a row of pixels
> #without GLX
> G63> export GRASS_NO_GLX_PBUFFERS=TRUE
> G63> export GRASS_NO_GLX_PIXMAPS=TRUE
> G63> nviz elevation.10m
> % Final Assembled Image will be 1904 x 2048
> Assembling Tiles
> pnmcat: Zero byte allocation
Well, it appears to make *some* difference, i.e. you're getting a
different error message.
Does removing the following from nviz2.2_script help?
# Set the cancel function for drawing
Nset_cancel_func update
