[GRASS-user] [bug #3041] nviz max resolution ppm image dump
Glynn Clements
glynn at gclements.plus.com
Wed Aug 30 12:02:17 EDT 2006
William Hargrove wrote:
> The 6.1.0 version of nviz dumps high res ppms perfectly after I comment
> out the off-screen section.
> So the bug that remains in the subsequent versions must come from code
> changes introduced since then.
The biggest change since 6.1 is that Togl has been updated to version
1.7.
Have you tried commenting out the following from nviz2.2_script (line
879)?
# Set the cancel function for drawing
Nset_cancel_func update
