[GRASS-user] r.in.onearth
Sören Gebbert
soerengebbert at gmx.de
Thu Aug 31 03:35:55 EDT 2006
the XML error message from the NASA server says the image you want
to download is too big -> more than 4096 cols. You need to change your
region resolution or you have to download the image in tiles smaller
than 4096 cols or rows.
The NASA server had send the XML error message instead of an image, so
r.in.gdal was not able to import.
best regards
soeren
lanczos at t-zones.sk schrieb:
> Trying to use the r.in.onearth on the way like below:
> r.in.onearth -l output=landsat_tm_7 file=/tmp/test tmband=visual 'wgetopt=-t 0'
> I got the error message like below (see the output in the P.S.) The Grass is 6.3.CVS from 20.8.2006, compiled on Ubuntu 6.06.
> What's wrong - something with Gdal, the wget or is it a bug of the r.in.onearth?
> Thanks
> Tomas
> p.s. the output:
> Will download and import LandsatTM Data with band visual
> ************** DOWNLOAD DATA ****************
> Requesting Data from http://wms.jpl.nasa.gov/wms.cgi
> --00:41:52-- http://wms.jpl.nasa.gov/wms.cgi
> => `/home/tomas/grassdata/srtm40_03/tomas/.tmp/tomas/10568.0/Image_global_mosaic_base_visual_6019_12020'
> Resolving wms.jpl.nasa.gov... 137.78.11.25
> Connecting to wms.jpl.nasa.gov|137.78.11.25|:80... connected.
> HTTP request sent, awaiting response... 200 OK
> Length: unspecified [application/vnd.ogc.se_xml]
> 0K 7.21 MB/s
> 00:41:54 (7.21 MB/s) - `/home/tomas/grassdata/srtm40_03/tomas/.tmp/tomas/10568.0/Image_global_mosaic_base_visual_6019_12020' saved [325]
> Downloaded file is not a GeoTiff file, but will try to import
> ************** CHECK DATA *****************
> ERROR 4: `/home/tomas/grassdata/srtm40_03/tomas/.tmp/tomas/10568.0/Image_global_mosaic_base_visual_6019_12020' not recognised as a supported file format.
> GDALOpen failed - 4
> GDALOpen failed - 4
> !-------------------BREAK---------------------!
> Downloaded file is not supported by gdal, or cannot be imported
> File of Type: XML document text
> Message from Server http://wms.jpl.nasa.gov/wms.cgi
> !------------BEGIN-ERROR-MESSGAE--------------!
> <?xml version='1.0' encoding="UTF-8" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM "http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd ">
> <ServiceExceptionReport version="1.1.0">
> <ServiceException>
> Requested image is too wide, max allowed width is 4096
> </ServiceException>
> </ServiceExceptionReport>
> !-------------END-ERROR-MESSGAE---------------!
> Finished
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
