[GRASS-user] Working with USA Public Land Survey System
Hamish
hamish_nospam at yahoo.com
Thu Aug 31 22:52:26 EDT 2006
> Henry House wrote:
> > I have a set of surveyed-section boundaries* for northern California
> > from the United States Public Land Survey System and would like to
> > use GRASS to find geometric fractions of these roughly square
> > sections. For example, I would like to divide a particular section
> > into equal quarters by bisecting it east-west and north-south and
> > then save the northwest quarter for further analysis. Can anyone
> > suggest a method to do this acurately?
> > * Used for legal descriptions of parcels given in terms of townships
> > and ranges.
Dylan Beaudette wrote:
> I think that the approach suggested by Hamish will work, but only when
> using a projection where the PLSS sections area oriented _exactly_ NS
> and EW. For example, looking at the PLSS data in the AEA projection
> that we use for many things, the sections are _not_ oriented as such:
> http://169.237.35.250/~dylan/temp/plss1.png
> However, there is an 'angle' operator in the v.mkgrid module, which
> may be able to account for this- although I cannot think of an
> _automated_ approach to deriving this angle.
> I have extracted a single section, marked red in the above image, like
> this:
> v.extract in=pls out=pls1 list=80800
> where 80800 is the cat, or feature id, of the section of interest.
> Zooming to the extents of this section:
> g.region vect=pls1
> http://169.237.35.250/~dylan/temp/plss2.png
> looking at the options for v.mkgrid:
> Parameters:
> map name of vector map
> grid number of ROWS and COLUMNS in grid
> position Where to place the grid:
> region - current region
> coor - use 'coor' and 'box' options
> options: region,coor
> default: region
> coor lower left EASTING and NORTHING coordinates of map
> box WIDTH and HEIGHT of boxes in grid
> angle angle of rotation (in degrees counter-clockwise)
> default: 0
> .... it looks like we might be able to define the grid in terms of a
> lower-left point, and the width and height of grid cells, and an angle
> of rotation.
> this will require some math, but might easily be accomplished with
> some right triangle-based trig.
> fitting the region to _exactly_ that of the bounding box of our
> extracted section:
> g.region `v.info -g pls1 | awk ' {gsub("north","n");
> gsub("south","s") ;
> gsub("east","e") ; gsub("west","w"); gsub("top","t") ;
> gsub("bottom","b")} $1 !~ /b|t/ {print $0}' | tr "\n" " "` -p
> extracting vertices of selected section: can do this with v.out.ascii
> and awk, or with v.to.points
If true N-S E-W grid is wanted, why not just run v.mkgrid in a lat-lon
location and reproject that to the target location with v.proj?
IIRC, v.mkgrid breaks the line ~ 3 times per box, so results can look
quite nice even when "curved". I think this is how Markus made this
screenshot?
http://grass.ibiblio.org/grass60/screenshots/images/etopo2_grass_laea_9_48N_0E.jpg
Hamish
