[GRASS-user] AAIGrid import-export problem
    Dylan Beaudette
    dylan.beaudette at gmail.com
    Fri Dec  1 13:23:22 EST 2006
Martin,
I am interested in hearing about the issues you have observed with
r.resamp.stats.
I too have noticed some odd behaviour when the input/output resolution is the
same : a systematic shift occurs.
an example with spearfish60:
g.region rast=elevation.dem
r.resamp.stats in=elevation.dem out=r method=average
d.rast elevation.dem
r.mapcalc "rd = float(elevation.dem - r)"
d.rast rd
r.info rd
Cheers,
Dylan
On Friday 01 December 2006 08:34, Martin Wegmann wrote:
> I tested various r.out.gdal settings (-r is a very handy function! - thanks
> Hamish) and found no errors using various files.
> Finally I ended up doing further test with r.resamp.stats where I found the
> problem.
> Hence r.out.gdal shows no inconsistency but r.resamp.stats - I'll post
> another message concerning this behaviour in a few minutes.
> Martin
> > > On Thursday 30 November 2006 13:43, Wolfgang wrote:
> > > > have you changed g.region to your new settings before export?
> > > I changed g.region res. during the r.resamp.stats but for export of
> > > the two raster g.region wasn't changed
> > > BTW r.info of the two raster gives same res/coord. for both.
> > what about with using the new region sensitive GDAL output? (resamples)
> > "r.out.gdal -r"
> > r.in.gdal out=NAME
> > g.region rast=NAME
> > r.out.gdal -r in=NAME
> > Hamish
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
