[GRASS-user] breaking out ("rescuing"?) islands
Sun Dec 3 20:59:40 EST 2006
David Norris wrote:
> The short story: Is there a way to "rescue" islands from vector areas?
> In other words, "break" the area up? This is hard for me to put into
> words, so I've drawn a picture to help explain what I want to do:
>     <https://netfiles.uiuc.edu/danorris/www/rescue-islands.png>
> The long story: I know it isn't topologically correct to do this. The
> problem is that I'm exporting this data as a shapefile for use in
> another program -- and that program doesn't understand "rings" in
> shapefiles! It sees all rings as outer rings, and doesn't understand
> holes. The only way to make this program see the existence of the hole
> would be to break up the polygon as in the diagram above so that it can
> be represented with one simple outer ring. I don't need the data to be
> modeled this way inside GRASS, just in the exported shapefile (or any
> other format that I could then translate into a shapefile).
> Aside: I know the proper solution would of course be to add outer/inner
> ring support to this external program, but unfortunately that's not an
> option. It's a kludge, but it's the only way I can think of to get valid
> data into this program!
maybe forget about areas and export as lines?
v.type "boundary,line"
Hamish
