[GRASS-user] 'ARNing: Cannot open driver 'dbf"
Raymond Fu
raymond_fu at yahoo.com
Mon Dec 4 03:24:00 EST 2006
thanks a lot, but the following driver error is still prompted as follows:
GRASS 6.1.cvs (spearfish60):~>v.db.connect -p map=roads driver=dbf
Vector map <roads> is connected by:
layer <1> table <roads> in database <home/xxx/spearfish60/PERMENANT/dbf/>
hoguh driver <dbf> with key <cat>
GRASS 6.1.cvs (spearfish60):~>g.copy vect=roads,roads_local
COPY [roads at PERMANENT] to current mapset as [roads_local]
DBMI-DBF driver error:
Cannot open dbf database: roads
WARNING: Cannot open database 'roads'
no database is open
WARNING: Cannot copy table
WARNING: Cannot copy roads at PERMANENT to current mapset as roads_local
Hamish <hamish_nospam at yahoo.com> wrote:
Raymond Fu wrote:
> I have installed GRASS 6.1 CVS and using the grass61.bat. However when
> I run certain DB related command like g.copy, it also returns
> ":No such driver available
> do I need to do something in the GRASS settings?
try testing/connecting to a database driver with the db.connect module.
Hamish
Send instant messages to your online friends http://uk.messenger.yahoo.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061204/64591c99/attachment.html
