[GRASS-user] v.surf.rst limitations?
Michael Perdue
michael_perdue at yahoo.ca
Mon Dec 4 10:53:18 EST 2006
Carlos,
To the best of my knowledge, the only limitation on v.surf.rst is
imposed by the limits of your hardware. IE, your probably running
into memory allocation problems. You can try increasing your swap
space, but be aware that v.surf.rst will take a painfully long time
to process that many points. Alternately, I'd recommend you give
r.in.xyz and v.surf.bspline a try.
Cheers,
Mike
On 4-Dec-06, at 3:49 AM, Carlos "Guâno" Grohmann wrote:
> Hello, I have this LIDAR dataset with abou 5.5 millions points that I
> imported with v.in.ascii -ztb, and I want to interpolate in a DEM with
> 5m resolution, which gives me about 13.5 million cells. When I try to
> run v.surf.rst (GRASS 6.3 cvs), it get killed after 30-40 minutes. Is
> there a limitation on v.surf.rst?
> thanks
> Carlos Henrique Grohmann - Guano
> Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
> Linux User #89721 - carlos dot grohmann at gmail dot com
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
