[GRASS-user] v.in.ascii don't create a table
Agustín Diez Castillo agustin.diez at uv.es
Mon Dec 4 12:16:56 EST 2006
It works for me with v.in.ascii, but no table is created when I used
v.hull, v.delaunay and v.patch. Is that right?
PPCMac G5 and the latest William's cvs.
Agustin
On Dec 1, 2006, at 7:18 PM, Martin Landa wrote:
> Hi,
> 2006/12/1, Michaël Rabotin <michaelrabotin at gmail.com>:
>> Hi everybody
>> I'm still on GRASS 6.0.1 and I want to create a vector point file by
>> v.in.ascii (point mode). It works good (a point vector is created )
>> but this
>> command doesn't create a dbf table associated with this vector
>> (I'm a on dbf
>> driver). Is this a bug of the 6.0.1 version or is there a
>> manipulation that
>> i forgot ?
>> I a also try the standard mode of v.in.ascii and it doesn't work too
>> Mick
> for me it works (creating vector map & attribute table) -- tested
> in 6.2/6.3
> Best regards, Martin
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/
> ~landa *
