[GRASS-user] Fwd: Re: [GRASS-dev] Re: v.in.gpsbabel bug? (with es
file)
Leonardo Lami
lami at faunalia.it
Tue Dec 5 11:55:52 EST 2006
Alle 16:48, martedì 5 dicembre 2006, Davide Spano ha scritto:
> Il giorno mar, 05/12/2006 alle 14.53 +0100, Leonardo Lami ha scritto:
> > Hi
> > I make some tests and I send you the gpsbabel output files.
> > For every type of gps (garmin 12, garmin 12xl and garmin 12 etrex) I make
> > two file:
> > a gpx file create from gpsbabel by "gpsbabel -w -i garmin -f /dev/ttyUSB0
> > -o gpx -F *.gpx"
> > a csv file create from v.in.gpsbabel using grass_write_ascii.style like
> > in the script
> > You can see that for "garmin 12" and "garmin 12xl" v.in.gpsbabel does not
> > transfer the field "name" (present in the gpx files) in the csv files.
> > Regards
> > Leonardo
> Hi all,
> the data is not downloaded because in the grass_write_ascii.style I did
> not put a field for that data (I believed that was only a progressive ID
> for the waypoint...)
But way the field is present in the case of garmin etrex also in the
grass_write_ascii.style?
> I propose to take a look at this page
> http://www.gpsbabel.org/htmldoc-1.3.2/style_define.html
> and tell me what fields are important to download, when we agree to the
> list, I'll fix the problem in the script.
I would add only the filed called "name" in the gpx file
Have someone other ideas?
Regasrd
Leonardo
> Davide
Leonardo Lami
email + jabber: lami at faunalia.it
www.faunalia.it
Cell: (+39)349-1310164 Tel+Fax: (+39) 0587-213742
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy
Leonardo Lami
www.faunalia.it
