[GRASS-user] 'ARNing: Cannot open driver 'dbf"
Raymond Fu
raymond_fu at yahoo.com
Tue Dec 5 23:07:10 EST 2006
hi,
actually, it is sample from spearfish60.
when I type
GRASS 6.1.cvs(spearfish60):~>g.gisenv
it display:
GISDBASE=/home/xxx
LOCATION_NAME=spearfish60
MAPSET=user1
MONITOR=x1
GRASS_GUI=tcltk
GRASS 6.1.cvs(spearfish60):~>cd$MAPSET
it change back to current directory.
do I need to set something before running the command?
Thank a lot.
Raymond
Hamish <hamish_nospam at yahoo.com> wrote:
Raymond Fu wrote:
> GRASS 6.1.cvs (spearfish60):~>v.db.connect -p map=roads driver=dbf
> Vector map is connected by:
> layer <1> table in database
> hoguh driver with key
> GRASS 6.1.cvs (spearfish60):~>g.copy vect=roads,roads_local
> COPY [roads at PERMANENT] to current mapset as [roads_local]
> DBMI-DBF driver error:
> Cannot open dbf database: roads
> WARNING: Cannot open database 'roads'
> no database is open
> WARNING: Cannot copy table
> WARNING: Cannot copy roads at PERMANENT to current mapset as roads_local
Does the database exist on the disk?
g.gisenv
cd $MAPSET
ls dbf/
Hamish
Send instant messages to your online friends http://uk.messenger.yahoo.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061206/1698933f/attachment.html
