[GRASS-user] grass 6.3cvs stability
Malte Halbey-Martin
malte at perlomat.de
Thu Dec 7 07:15:14 EST 2006
Hello Precila,
when you run
g.list vect
on the command line all available vector files are listed in the
location you are working. Does your imported cities.grc appear?
Malte
Precila Salcedo schrieb:
> --- Hamish <hamish_nospam at yahoo.com> wrote:
>> Precila Salcedo wrote:
>>> thanks a lot, i tried doing several things but
>> failed
>>> here's what i did:
>>> v.in.ogr -l dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP
>> output=cities.grc min_area=0.0001 snap=-1
>>> Data source contains 1 layers:
>>> CITIES
>> Hi Precila,
>> from the help page:
>> Flags:
>> -l List available layers in data source and exit
>> so when you used the list flag it exited before
>> importing anything.
>> try this:
>> v.in.ogr dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP
>> output=cities.grc
>> which is the same as this:
>> v.in.ogr dsn=C:/ESRI/ESRIDATA/WORLD/ layer=CITIES
>> output=cities.grc
>> Hamish
> Hi Hamish,
> i tried your suggestion by opening grass and typing
> the command straight on the Output GIS.m panel (lower
> half of the panel) then RUN it;
> output=cities.grc
> how will i open it now?..i was looking for the file
> cities.grc but cant find it, was it automatically
> saved on my default location or somewhere else? my
> default dataset is Spearfish60 PERMANENT. wil i open
> it using file/workspace/open or using
> file/import/vector map???? ..im having difficulty with
> this. thanks a lot.
> Precy
> ____________________________________________________________________________________
> Any questions? Get answers on any topic at www.Answers.yahoo.com. Try it now.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
