[GRASS-user] problems using r.proj with large data set
JerryNelson
gnelson at uiuc.edu
Thu Dec 7 14:48:32 EST 2006
Further to this message.
I did a cvs update and compiled the result with --enable-largefile option.
The make process worked ok and it is possible that the r.proj ran a bit
longer before it crashed with the message Killed but it still died.
Is this a problem with large files that I will just have to work around or
is it something to do with my setup?
Any help appreciated.
Thanks, Jerry
JerryNelson wrote:
> I am working with SRTM elevation for the Horn of Africa. The data comes in
> chunks, which I have patched together to cover all the countries I'm
> interested in (South to Uganda and west to Ethiopia). The data are
> originally in lat-long but I want to calculate slope so my understanding
> is
> that I need to project. I choose utm 37N as being roughly in the center of
> the region and then extend the bounds of the working region to include all
> the countries.
> I'm using grass63 that I compiled on a machine running CentOS, which is a
> version of Redhat. The machine has 2 gb of memory. The command runs for
> awhile and then stops, sometimes with a complain about memory or sometimes
> with the word Killed. Any suggestions greatly appreciated!
> Jerry
> r.proj input=AfricaHornElev location=world mapset=PERMANENT
> output=AfricaHornElev method=cubic
> Input Projection Parameters: +proj=longlat +a=6378137 +rf=298.257223563
> +no_defs Input Unit Factor: 1
> Output Projection Parameters: +proj=utm +zone=37 +a=6378137
> +rf=298.257223563 +n o_defs Output Unit Factor: 1
> Input:
> Cols: 25128 (25200)
> Rows: 24696 (27600)
> North: 15.580000 (18.000000)
> South: -5.000000 (-5.000000)
> West: 31.000000 (31.000000)
> East: 51.940000 (52.000000)
> ew-res: 0.000833
> ns-res: 0.000833
> Output:
> Cols: 19262 (20328)
> Rows: 19223 (19507)
> North: 1722315.000000 (1722315.000000)
> South: -566189.703183 (-600000.000000)
> West: -393095.238095 (-520000.000000)
> East: 1900000.000000 (1900000.000000)
> ew-res: 119.047619
> ns-res: 119.050341
> Allocating memory and reading input map...
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
View this message in context: http://www.nabble.com/problems-using-r.proj-with-large-data-set-tf2775725.html#a7746318
Sent from the Grass - Users mailing list archive at Nabble.com.
