[GRASS-user] Failed to process SRS definition when TIGER2000 is being imported.
Tom Russo russo at bogodyn.org
Fri Dec 8 16:49:57 EST 2006
On Fri, Dec 08, 2006 at 05:07:49PM +0800, we recorded a bogon-computron collision of the <raymond_fu at yahoo.com> flavor, containing:
> By the way when I try to import ESRI Shape files(TIGER2000) by the fellowing command ogr2ogr -s_srs "+init=epsg:4269" -t_srs "+init=epsg:26713" tgr46081lKA_UTM13_nad27.shp tgr46081lkA.shp, it returns "Failed to process SRS definition: +init=epsg:4269.   Do I need install anything additional plugin to make it work?
Try instead:
ogr2ogr -s_srs EPSG:4269 -t_srs EPSG:26713
Tom Russo    KM5VY   SAR502   DM64ux          http://www.swcp.com/~russo/
Tijeras, NM  QRPL#1592 K2#398  SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
 one trick, rational thinking, but when you're good and crazy, oooh, oooh,
 oooh, the sky is the limit!"  --- The Tick
