[GRASS-user] Release Candidate and CVS diff
    Brad Douglas
    rez at touchofmadness.com
    Sat Dec  9 09:17:15 EST 2006
On Sat, 2006-12-09 at 12:16 +0100, Michele wrote:
> Dear All,
> if I use the "CVS diff snapshot" to grass6.2.0 Weekly
> available, I'll have the same code of the release candidate,
> Am I right?
I'm not certain if the patches are cumulative.  Someone else may be
better to answer that.
> To use the "diff" file is a better choice for me having a very
> slow connection and it will preserve bandwidth...
If you're interested in saving bandwidth over the long term, you might
want to checkout the stable branch from CVS.  The first time is a bit of
a pain, but from then on, all you need to do is 'cvs up -PAd' and you're
current.
CVS tags are here with brief instructions:
http://grass.itc.it/devel/cvstags.php
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
