[GRASS-user] r.le.setup trouble
Koen Hufkens
koen.hufkens at ua.ac.be
Mon Dec 11 09:07:45 EST 2006
Thank you, but it doesn't seem to work. Probably because I work on an
amd64 machine not i386.
But I'll keep looking, my current efforts to install from tarball were
not a succes so I'll try to get hold of a .dep package.
Koen
On Mon, 2006-12-11 at 14:53 +0100, Jachym Cepicky wrote:
> hi,
> On Mon, Dec 11, 2006 at 02:29:46PM +0100, Koen Hufkens wrote:
> > I'm using 6.0.2 from the ubuntu repositories.
> > I'm currently looking for a repository offering a more recent release
> > but I don't seem to find one.
> try this:
> deb http://les-ejk.cz/ubuntu edgy multiverse
> I got at least one positive feedback
> please, let me know, if the packages are all right
> thank you
> jachym
> P.S. GRASS 6.2.0, gdal 1.3.2, proj 4.5, qgis 0.8
> > It has something to with this release because I tried the same thing on
> > the computer of friend of mine and it gave the same error.
> > Koen
> > On Tue, 2006-12-12 at 00:11 +1300, Hamish wrote:
> > > Koen Hufkens wrote:
> > > > I have some trouble with the r.le.setup module, maybe someone knows
> > > > the solution to this.
> > > > When I run r.le.setup to define my moving window specification to use
> > > > in further r.le analysis the module stalls when I'm being asked to
> > > > specify the size of my (rectangular) moving window. If I do so, let's
> > > > say a 3 by 3 window, it complains about a 0 being present while I
> > > > didn't type any zeros.
> > > > The full output of the procedure I followed is listed below:
> > > > HOW WILL YOU SPECIFY THE MOVING WINDOW?
> > > > Use keyboard to enter moving window dimensions 1
> > > > Use mouse to draw moving window 2
> > > > Which Number? 1
> > > > If a MASK is not present (see r.mask) a beep may sound
> > > > and a WARNING may be printed that can be ignored.
> > > > If a MASK is present there will be no warning.
> > > > WARNING: unable to open raster map [MASK in PERMANENT]
> > > > Do you want to sample using rectangles
> > > > (including squares) (y) or circles (n)? (y/n) [y]
> > > > Enter number of COLUMNS & ROWS for the dimensions of
> > > > the moving window (e.g., 10 10): 3 3
> > > > You entered a dimension as 0; enter dimensions again
> > > > Entering other delimiters other than space didn't work either.
> > > > Any clues why I can't define ar rectangular moving window. I tried a
> > > > circular one and that did work?
> > > What version of GRASS? There were substantial fixes for r.le.setup right
> > > before GRASS 6.2.0 was released. If 6.3-cvs, check out r.li too.
> > > The above works fine for me using the spearfish dataset. Space as the
> > > delim between "3 3". Draws the box, then moves on to the next question.
> > > here is the relevant code from r.le.setup/mv_wind.c
> > > /* if sampling using rectangles/squares */
> > > else {
> > > back:
> > > fprintf(stderr, "\n Enter number of COLUMNS & ROWS for the dimensions of");
> > > fprintf(stderr, "\n the moving window (e.g., 10 10): ");
> > > numtrap(2, tmp);
> > > u_w = fabs(tmp[0]);
> > > u_l = fabs(tmp[1]);
> > > u_w0 = fabs(tmp[0])/mx[0];
> > > u_l0 = fabs(tmp[1])/mx[1];
> > > /* trap possible errors in dimensions */
> > > if (!u_w0 || !u_l0) {
> > > fprintf(stderr, "\n You entered a dimension as 0; enter dimensions again\n");
> > > goto back;
> > > numtrap() is at the end of r.le.setup/sample.c.
> > > Hamish
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
