[GRASS-user] Grass installation problem on Solaris 9
Brad Douglas
rez at touchofmadness.com
Thu Dec 14 03:15:59 EST 2006
On Thu, 2006-12-14 at 10:57 +0500, capricorn 80 wrote:
> Hi ! I have to past full messages so that u people can figure out whats the
> main problem in it So that i can install grass on solaris.
> Following are my messages when i compile grass-6.2.1RC1 on solaris 9.
> GRASS is now configured for: sparc-sun-solaris2.9
> Source directory: /opt/grass/grass-6.2.1RC1
> Build directory: /opt/grass/grass-6.2.1RC1
> Installation directory: /usr/local/grass-6.2.1RC1
> Startup script in directory: ${exec_prefix}/bin
> C compiler: gcc -g -O2
> C++ compiler:
> FORTRAN compiler:
> Building shared libraries: yes
> 64bit support: yes
> OpenGL platform: X11
> NVIZ: yes
> BLAS support: no
> C++ support: no
> DWG support: no
> FFMPEG support: no
> FFTW support: yes
> FreeType support: no
> GDAL support: yes
> GLw support: no
> JPEG support: yes
> LAPACK support: no
> Large File Support (LFS): yes
> Motif support: no
> MySQL support: no
> NLS support: no
> ODBC support: no
> OGR support: yes
> OpenGL support: yes
> PNG support: yes
> PostgreSQL support: yes
> Python support: yes
> Readline support: no
> SQLite support: no
> Tcl/Tk support: yes
> TIFF support: yes
> X11 support: yes
> bash-2.05# make
> Then i execute command Following modules are missing the 'description.html'
> file in src code:
> i.find
> GRASS GIS compilation log
> Started compilation: Thu Dec 14 09:29:03 PKT 2006
> Errors in:
> /opt/grass/grass-6.2.1RC1/lib/gmath
> /opt/grass/grass-6.2.1RC1/lib/db/sqlp
> /opt/grass/grass-6.2.1RC1/lib/imagery
> /opt/grass/grass-6.2.1RC1/lib/rst/interp_float
> /opt/grass/grass-6.2.1RC1/lib/init
> /opt/grass/grass-6.2.1RC1/db/drivers/dbf
> /opt/grass/grass-6.2.1RC1/db/drivers/postgres
> /opt/grass/grass-6.2.1RC1/db/drivers/ogr
> /opt/grass/grass-6.2.1RC1/display/d.colors
> /opt/grass/grass-6.2.1RC1/general/g.access
> /opt/grass/grass-6.2.1RC1/general/g.mapsets
> /opt/grass/grass-6.2.1RC1/general/g.transform
> /opt/grass/grass-6.2.1RC1/imagery/i.class
> and few more messages like this.
> Then i change the directory and try to make i.e
> bash-2.05# cd /opt/grass/grass-6.2.1RC1/lib/gmath
> bash-2.05# make
> <unknown> 0x18
> /usr/local/lib/libfftw3.a(t1_4.o)
> <unknown> 0x14
> /usr/local/lib/libfftw3.a(t1_5.o)
> <unknown> 0x18
> <unknown> 0x14
> /usr/local/lib/libfftw3.a(t1_6.o)
> <unknown> 0x18
> <unknown> 0x14
> /usr/local/lib/libfftw3.a(t1_7.o)
> <unknown> 0x18
> <unknown> 0x14
> /usr/local/lib/libfftw3.a(t1_8.o)
> <unknown> 0x18
> <unknown> 0x14
> /usr/local/lib/libfftw3.a(t1_9.o)
> <unknown> 0x18
> <unknown> 0x14
> /usr/local/lib/libfftw3.a(t1_10.o)
> <unknown> 0x18
> <unknown> 0x14
> /usr/local/lib/libfftw3.a(t1_12.o)
> <unknown> 0x18
> ld: fatal: relocations remain against allocatable but non-writable sections
> collect2: ld returned 1 exit status
> make: ***
> [/opt/grass/grass-6.2.1RC1/dist.sparc-sun-solaris2.9/lib/libgrass_gmath.6.2.1RC1.so]
> Error 1
This thread may be related:
http://www.filibeto.org/pipermail/solaris-users/2004-March/000660.html
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
