[GRASS-dev] Re: [GRASS-user] problems using r.proj with large data set
Dylan Beaudette dylan.beaudette at gmail.com
Mon Dec 18 18:34:53 EST 2006
On Monday 18 December 2006 13:07, Glynn Clements wrote:
> Dylan Beaudette wrote:
> > Interesting work Gylnn. Not having tried your module yet, I am wondering:
> > does the segmenting result in any sort of artifacts in the output raster?
> > i.e. I have seen artifaces related to segmenting with the v.surf.rst
> > module before, when optimal settings are not used.
> No. The projection algorithm is unchanged; the only difference is in
> the mechanism used to retrieve the contents of a specific source cell.
Great.
> The normal r.proj essentially does:
> 	FCELL val = ibuffer[row][col];
> OTOH, with r.proj.seg the code is more like:
> 	typedef FCELL block[BDIM][BDIM];
> 	#define HI(i) ((i) / BDIM)
> 	#define LO(i) ((i) % BDIM)
> 	block *b = cache->blocks[HI(row)][HI(col)];
> 	if (!b) /* block not in memory */
> 		b = cache->blocks[HI(row)][HI(col)] = read_block(cache, row, col);
> 	FCELL val = b[LO(row)][LO(col)];
> The above isn't actual code; for a start, BDIM is a power of 2, and
> the HI/LO macros use shift/mask instead of division/remainder. Also,
> the details are hidden inside macros to simplify the application code,
> which actually looks like:
> 	FCELL *p = CPTR(cache,row,col);
> The main point to note is that interpolation isn't affected by segment
> boundaries, which I suspect is probably what was happening with
> v.surf.rst.
Ok, this was my main concern (unfounded it seems).
> Assuming that it works out okay, I'll probably end up merging
> r.proj.seg into r.proj, with the macro handling the details of whether
> to read from a tile cache (large maps) or from a single block of
> memory (small maps).
This makes sense. For small maps is it much faster to not use the cache?
> Actually, there is one minor difference in the observable behaviour of
> the two programs. r.proj.seg doesn't include the half-baked
> null-handling hack used by r.proj for the bilinear and bicubic
> methods; it just propagates the nulls.
Interesting. I am rather new to r.proj, as I have used gdalwarp for everything
until now.
> Consequently, r.proj.seg will tend to enlarge null regions slightly
> when using bilinear or bicubic interpolation, whereas r.proj tends to
> fill them in (with values whose accuracy is rather dubious). If you
> want null regions filled, run r.fillnulls first.
Indeed. Was this a 'documented' feature?
> BTW, in the course of writing r.proj.seg, I discovered that
> method=bilinear was seriously broken (it had the row/column swapped,
> essentially flipping each source cell along the main diagonal). The
> fact that no-one noticed until now suggests that either no-one used
> method=bilinear, or they didn't pay much attention to the results.
Would this accound for banding in the output from any method=bilinear warps? I
have noticed this before, but had been told that it was an artifact in the
source data.
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
