[GRASS-user] NVIS
Hamish
hamish_nospam at yahoo.com
Tue Dec 19 23:02:06 EST 2006
Abbott, Dawn wrote:
> This is what I have in my shapefile
> | Number of points: 0 Number of areas: 15518 |
> | Number of lines: 0 Number of islands: 1 |
> | Number of boundaries: 31238 Number of faces: 0 |
> | Number of centroids: 15518 Number of kernels: 0 |
> When I load my shape file into NVIZ the window writes that the file has
> been loaded however, I do not see anything.
I may be totally wrong, but I don't think vector areas work well with NIVZ.
try
g.region vect=yourmap
g.region -p
#if rows, columns > 2000x2000 set the resolution coarser:
g.region res=100 -a
then try a raster version: v.to.rast
or just
r.mapcalc basemap=0
nviz elev=basemap
Then display the vector on that surface, or go to the NVIZ raster panel
and set basemap's color surface attribute to the v.to.rast result.
Hamish
