[GRASSLIST:10126] RE: updates to gism2 - Feb2, 2006
C. H. Roosevelt
chr at bu.edu
Thu Feb 2 09:59:06 EST 2006
Hi again,
Thank you again for the most recent fixes!
I can verify Eric's errors 1-3 regarding workspace resource files,
again working on MacOSX. The only notes I'd add include the following:
> 1) Clicking the 'Open existing workspace file' button opens a 'Save
> File'
> dialog box. Shouldn't this be an Open File box?
This seems only to be a dialog box *title* problem: the button does
actually open (and not save) a resource file.
> 2) Trying to open a Workspace file through File/Groups/Open menu
> gives an
> error. I've attached it as 'Open Workspace Error.log'.
> 3) I created a workspace file from scratch. I added 2 rasters to
> the gis
> manager, then clicked File/Groups/Save as which gave the error message
> attached in 'Save_Workspace_Error.log'. I am able to save the
> workspace
> using the GUI button on the display manager, however. The saved
> workspace
> file re-opens normally.
While the GUI buttons related to resource files all work for me, the
only command under the menus (File>Groups> ...) that seems to work is
"Close". By the same token, the only keyboard shortcut that works in
this menu is ctrl-W for "Close."
Chris
On Feb 2, 2006, at 9:29 AM, Patton, Eric wrote:
> Hi Michael,
> I downloaded gism_rc1_20060201 this morning and gave it a try;
> thanks for
> the updates! We're definitely getting closer here.
> Some observations:
> File'
> gives an
> the gis
> workspace
> workspace
> 4) Most Grass commands typed into the run dialog don't seem to do
> anything.
> I only tried a few commands, i.e. g.region -p, d.rast
> map=rastername don't
> run, but r.composite does. Do only a subset of Grass programs run
> in this
> dialog?
> 5) Once a code block is pasted into the 'run' dialog, clicking the
> 'save'
> button produces an error message, which is attached as
> Command_Save_Error.log.
> HTH,
> ~ Eric.
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu
> To: grass developers list; Multiple recipients of list
> Sent: 2/1/2006 7:55 PM
> Subject: [GRASSLIST:10120] updates to gism2
> I posted to my web site and Markus helped me commit to the cvs a
> set of
> updates to the GIS Manager 2 GUI that addresses some of the issues
> that
> popped up over the last couple days.
> I noticed that I cannot produce text overlays on my Mac using
> d.text or
> d.text.freetype. I'd like to know if this is the same under other OS's
> also. d.label does work, however.
> d.text.freetype has not worked on the Mac since the upgrade to
> OSX10.4,
> but d.text did work. So I need to know if this is a Mac issue or
> everyone has the same lack of text under the new TclTk canvas
> displays.
> If the latter, I can add a TclTk text module that will do essentially
> the same thing as d.text.freetype and should work on all systems.
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> <http://www.public.asu.edu/~cmbarton>
> <Open_Workspace_Error.log>
> <Save_Workspace_Error.log>
> <Command_Save_Error.log>
C. H. Roosevelt
Archaeology Department
Boston University
675 Commonwealth Avenue
Boston, MA, 02215-1406
Tel: (617) 358-1652 (direct)
Tel: (617) 353-3415 (main office)
Fax: (617) 353-6800
E-mail: chr at bu.edu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060202/2176ee21/attachment.html
