[GRASSLIST:10129] Re: Combining layers
ivan marchesini marchesini at unipg.it
Thu Feb 2 09:48:31 EST 2006
Hi Steven,
I think you can try with "v.patch"!! the last version support the join
of the tables.. but the tables must have the same columns I think!!!
otherway if you don't care of attributes simply "v.patch" without
joining tables and then "v.build.polylines" and then v.out.ogr...
hope this help
Il giorno mer, 01/02/2006 alle 12.55 -0600, Steven Gordon ha scritto:
> This is a beginner's question...
> If I have imported 13 layers of roads data (each layer represents a
> county), can I combine the layers so that there is only 1 layer in my
> map?
> I would like to build polylines for 1 layer and then export that in
> shapefile format.
>    Steven Gordon
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
