[GRASSLIST:10147] Re: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend window interferes with map window
Michael Barton michael.barton at asu.edu
Fri Feb 3 14:00:48 EST 2006
At the moment, you just need to turn off the graphic legend option if you
use it in the new GIS Manager. Given the way that this uses the x11
monitors, it requires some work to come up with a way to display a legend in
the new GIS Manager AND not break the script for other users.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Michael Barton <michael.barton at asu.edu>
> Date: Thu, 02 Feb 2006 12:50:55 -0700
> To: Michael Barton <michael.barton at asu.edu>
> Conversation: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend
> Subject: FW: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend window
> __________________________________________
> phone: 480-965-6213
> fax: 480-965-7671
> ------ Forwarded Message
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Thu,  2 Feb 2006 11:53:31 +0100 (CET)
> To: <grass5 at grass.itc.it>
> Subject: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend window
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4052
> Subject: gis.m: d.vect.thematic legend window interferes with map window
> Platform: GNU/Linux/x86
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs_head_20060202
> With today's CVS head tree freshly compiled, there seems to be a problem of
> inteference between the map and the legend in d.vect.thematic. Two cases:
> - When I uncheck "create graphic legend", then the x0 monitor opens and all
> the GUI elements freeze until I close this monitor. Then the thematic map is
> correctly displayed in the map display.
> - When I check "create graphic legend", the same happens with the x0 monitor
> (i.e. the GUI freezes until I close the x0 monitor), but then it is the
> legend which is displayed in the map display, not the map...
> Moritz
> -------------------------------------------- Managed by Request Tracker
> ------ End of Forwarded Message
