[GRASSLIST:10234] RE: Three questions on ps.map
Ian MacMillan
Ian.MacMillan at pomona.edu
Thu Feb 9 18:21:11 EST 2006
Morten, i don't have answers for number one, but you could try to use
the TEXT command with ps.map to force the units next to your scalebar.
A hack, but it shoudl work.
You should be able to just draw outlines of vectors with vareas, just
make your fcolor 'none'.
G'luck
-Ian
On Feb 9, 2006, at 6:27 AM, Morten Sickel wrote:
> Sorry for 'bumping' my post, but these problems are important to me.
> Any
> body having an Idea? 8The first one, I can fix with some manual editing
> of the ps file, the others are worse..
> Morten
> ________________________________
> From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
> Behalf Of Morten Sickel
> Sent: Tuesday, February 07, 2006 9:01 PM
> To: grasslist at baylor.edu
> Subject: [GRASSLIST:10194] Three questions on ps.map
> Hi
> I am using ps.map and I have a few questions regarding it. My map is
> build up with a number of vector layers
> 1) I am getting a frame around the map. Is that possible to avoid?
> 2) Is it possible to put the unit on the scale bar?
> 3) I have a vector layer with a closed polygon where I just want to
> draw
> the outline. I tried using vlines, but then nothing showed up. This may
> also be some problem with how the layer is defined.
> Morten
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
- Dave Barry
This message has been scanned by Postini anti-virus software.
