[GRASSLIST:10244] Re: Error with Postgres on Mac OSX, most recent
cvs
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Fri Feb 10 04:21:58 EST 2006
Hi Nick
>The most recent cvs build on Lorenzo Moretti's site for Mac OSX, of
>1/24/06, gives me an error when trying to access postgres:
>dyld: Library not loaded: /usr/local/pgsql/lib/libpq.3.dylib
> Referenced from:
>/Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs/driver/db/pg
> Reason: image not found
>dbmi: Protocol error
>WARNING: Cannot open driver
>It's not able to load /usr/local/pgsql/lib/libpq.3.dylib because on
>my machine postgres isn't installed there - it's in the /Library
>directory, because I installed it using pgsqlformac, which installed
>it into this non-standard location. This version of postgres used
>to be on sourceforge; it is now at
>http://web.mac.com/dru_satori/iWeb/PostgreSQLforMac/Welcome.html.
>Maybe this wasn't the smartest move on my part, but it worked til
>now.
>Would it be better for me to remove and reinstall postgres into
>/usr/local/pgsql, or can future versions figure out where postgres
>is installed?
>Thanks,
>Nick Cahill
Thanks for your report
Open your terminal and enter (copy and paste is better):
% install_name_tool -change /usr/local/pgsql/lib/libpq.3.dylib
/usr/local/grasslib/lib/libpq.3.dylib
... and press return
I'll fix this problem in the next release.
Try and you can use PgSQL.
Bye
__________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
ENEA - Ente Nazionale per le Nuove Tecnologie, l'Energia e l'Ambiente
ENEA - The Italian Agency for New Technologies, Energy and the Environment
