[GRASSLIST:10397] Re: [Qgis-user] unable to display PostGIS layer
Martin Landa
landa.martin at gmail.com
Sat Feb 18 14:02:00 EST 2006
thanks to Peter, problem solved. I have enabled
default_with_oids = on
in postgresql.conf.
Now it works...
Thanks again,
best regards Martin
2006/2/18, Peter Pavlicko <ppavlicko at gmail.com>:
> zdravim,
> je to problem Postgres-u...
> qgis vyzaduje pri manipulacii s tabulkami oids, avsak standardna
> instalacia postgres-u 8.1.* ju nema ako default...
> skus odremovat v postgresql.conf with-oids a restartnut postgres...
> a vyexportovat subor este raz a potom by to malo ficat....
> pp
> On 2/18/06, Martin Landa <landa.martin at gmail.com> wrote:
> > Hi all,
> > I have created a PostGIS layer by v.out.ogr.
> > v.out.ogr in=cr olayer=cr dsn="PG:dbname=pgis_cr" type=area
> > format="PostgreSQL"
> > Then trying to display this layer in QGIS I get the following errors:
> > No oid column in table ...
> > Qgis row key was not set.
> > public.cr (wkb_geometry) sql= is an invalid layer - not loaded
> > Fresh CVS GRASS & QGIS
> > PostGIS 1.1.1
> > GDAL/OGR 1.3.1
> > Best regards, Martin
> > ps: ALTER TABLE cr RENAME ogc_fid to oid; helped, but I don't like
> > this solution...
> > This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
> > for problems? Stop! Download the new AJAX search engine that makes
> > searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
> > http://sel.as-us.falkag.net/sel?cmdlnk&kid3432&bid#0486&dat1642
> > Qgis-user mailing list
> > Qgis-user at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/qgis-user
