[GRASSLIST:10472] Re: [GRASS5] Re: QGIS/GRASS for Windows 060217
Markus Neteler
neteler at itc.it
Tue Feb 21 08:44:54 EST 2006
On Tue, Feb 21, 2006 at 02:33:34PM +0100, Radim Blazek wrote:
> On 2/21/06, "Peter Löwe" <peter.loewe at gmx.de> wrote:
> > The problem can be reproduced:
> > OS: Windows XP Professional Service Pack 2, no admin privileges
> > 1) Download & unpacking of qgis-0.7.9-win32-060217.zip (34MB)
> > 2) Download of spearfish_grass60data.tar.gz
> > 3) Unpacking of the spearfish location by doubleclicking/"WinZip" using the
> > defaults.
> Here is the problem. By default, WinZip is using 'TAR file smart
> CR/LF conversion'.
> If you go to Options->Configuration->Miscelaneous and disable the
> TAR CR/LF conversion it should work.
> Obviously this is not convenient, I think that we should probably prepare
> demo data packages also in zip format.
Done:
http://grass.itc.it/download/data6.php
-> SPEARFISH 6.0 data set
-> tar.gz
-> zip
Enjoy
Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
