[GRASSLIST:10474] Re: QGIS/GRASS for Windows 060217
Radim Blazek
radim.blazek at gmail.com
Tue Feb 21 08:50:23 EST 2006
I found another problem, map canvas is not redrawn when
when raster is loaded (works for vectors). You need to
zoom/pan/full-extent or resize/hide-show qgis window.
I'll try to fix that but the qgis canvas will be replaced by Martin's code
soon anyway.
Radim
On 2/21/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> On 2/21/06, "Peter Löwe" <peter.loewe at gmx.de> wrote:
> > The problem can be reproduced:
> > OS: Windows XP Professional Service Pack 2, no admin privileges
> > 1) Download & unpacking of qgis-0.7.9-win32-060217.zip (34MB)
> > 2) Download of spearfish_grass60data.tar.gz
> > 3) Unpacking of the spearfish location by doubleclicking/"WinZip" using the
> > defaults.
> Here is the problem. By default, WinZip is using 'TAR file smart
> CR/LF conversion'.
> If you go to Options->Configuration->Miscelaneous and disable the
> TAR CR/LF conversion it should work.
> Obviously this is not convenient, I think that we should probably prepare
> demo data packages also in zip format.
> Radim
> > 4) Opening vectors from the spearfish location works fine.
> > 5) Opening raster layers fails, same error message as discussed below.
> > >> > However, when trying to open any grass raster, I get the following
> > >error:
> > >> > "C:/..../locations//spearfish60/PERMANENT/cellhd/elevation.10m is not
> > >a
> > >> > supported raster data source".
> > >> > Is raster processing still unstable or are maybe specific read/write
> > >> > privileges to be set ?
> > >Today I tested GRASS rasters with qgis-0.7.9-win32-060217
> > >and Spearfish and it works for me.
> > >Do you have other versions of GDAL on your system?
> > >It should not be problem because Windows should first search for
> > >DLL in the directory where application is located.
> > >Anybody other had success/problems with GRASS rasters?
> > Dr. Peter Löwe
> > Diplom-Geograph
> > <loewe at geomancers.net>
> > 10 GB Mailbox, 100 FreeSMS/Monat http://www.gmx.net/de/go/topmail
> > +++ GMX - die erste Adresse für Mail, Message, More +++
