[GRASSLIST:10482] Question about v.vol.rst in GRASS 6.1
Thomas Adams
Thomas.Adams at noaa.gov
Tue Feb 21 11:13:52 EST 2006
List:
I am trying to use v.vol.rst in GRASS 6.1cvs on a Linux system. First,
using the command:
v.vol.rst -c input=sta_obs_temp_20050731_08 wcolumn=temp
maskmap=gtopo30.eastern.us segmax=700 tension=10 cvdev=cvdev_map
I get the following:
118 records selected from table
WARNING: some points outside of region -- will ignore...
WARNING: strip exists with insufficient data
Processing all selected output files will require 0 bytes of disk space
for temp files
WARNING: There are points outside specified 2D/3D region--ignored 118
points (total points: 118)
ERROR: zero points in the given region!
ERROR: input failed!
I just don't understand what's going on; all the points appear when I
display them. I'm able to query the points and perform other analyses,
such as, v.surf.idw.
Regards,
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
