[GRASSLIST:10492] Labels and ps.map
Nick Cahill
ndcahill at facstaff.wisc.edu
Tue Feb 21 13:15:03 EST 2006
Dear Grass Gurus,
Is there a reason why d.m and gis.m can display point vector
attributes as labels, but this can't be output to a postscript file;
and ps.map has to rely on the - I assume, somewhat outdated - method
of using a separate label file? Currently, to get labels to come out
correctly in ps.map, I have to run ps.map, look at the postscript
output, find that the labels are a bit too big or something, make a
whole new label file with different parameters, and start again; and
this usually takes a number of iterations. It would be much more
convenient (for me at least, as a user) to have site labels be part
of vector display within ps.map, so you could have e.g.
vpoints vector
type point or/and centroid
layer # (layer number used with cats/where/sizecol options)
cats list of categories (e.g. 1,3,5-7)
where SQL where statement like: vlastnik = 'Cimrman'
masked [y|n]
color color
fcolor color
**attlabel (attribute column)
**attlabelsize (in points or whatever)
**font, color, etc.
Or am I missing something obvious?
Thank you,
Nick Cahill
