[GRASSLIST:10516] Problem using v.surf.rst
Luca Casagrande luca.casagrande at gmail.com
Wed Feb 22 08:24:43 EST 2006
Hi guys!
I got a SHP 3d with countour line at 25m and using this,i had to create a dem;
I imported the shp using v.in.ogr and enabling the flag for 3d shp and this is
the v.info output:
Map Scale:  1:1
Map format: native
Type of Map:  Vector (level: 2)
Number of points:       	0               Number of areas:      0
Number of lines:        		2918           Number of islands:    0
Number of boundaries:   	0            Number of faces:      0
Number of centroids:    	0             Number of kernels:    0
Map is 3D:              		1
Number of dblinks:      	1
The associated table got element like those one:
id | cat | id | igds_layer | eq_lvls | altitude
1	1    0		....		5	  100m (the value of the cl)
Doing a query on the vector map i noticed this anywhere:
map: 'cdl25m'
mapset: 'PERMANENT'
feature type: Line
length: 4008.907401
Line height: 0.000000   <== Is this ok with 3d file?
Then I started v.surf.rst with this vector (after setting the res to 20):
v.surf.rst input=cdl25m layer=0 dmin=0.5 elev=dem20 tension=90
But the raster output has got all cell with 0 altitude...what i am missing?
Thx
Luca
"E' molto più bello sapere qualcosa di tutto, che tutto di una cosa (Blaise
Pascal)."
GENTOO-GIS Development Team
jabber: casagrande at jabber.linux.it
