[GRASSLIST:10522] continued problems with v.in.ogr and PROJ_INFO
Chris Fonnesbeck
fonnesbeck at gmail.com
Wed Feb 22 10:54:43 EST 2006
I thought I had this problem licked, but apparently not:
v.in.ogr dsn=./ layer=Lee_Sept05_UtmNad27 location=lee out=zones
Creates a layer called "zones" in a new location "lee", but there is
no PROJ_INFO file, despite the attached prj file associated with the
shapefile. I am using a Feb 18 cvs build, and this has worked once
before, but apparently, not consistently.
Thanks,
C.
Chris Fonnesbeck + Atlanta, GA + http://trichech.us
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060222/8d200196/Lee_Sept05_UtmNad27.obj
