[GRASSLIST:10525] Re: Problem using v.surf.rst
Maciek Sieczka
werchowyna at epf.pl
Wed Feb 22 15:00:01 EST 2006
On Wed, 22 Feb 2006 13:24:43 +0000
Luca Casagrande <luca.casagrande at gmail.com> wrote:
> Hi guys!
> I got a SHP 3d with countour line at 25m and using this,i had to
> create a dem; I imported the shp using v.in.ogr and enabling the flag
> for 3d shp and this is the v.info output:
> Map Scale:
> 1:1 Map format:
> native
> Type of Map: Vector (level:
> 2) Number of points: 0 Number of
> areas: 0 Number of lines: 2918
> Number of islands: 0 Number of boundaries: 0
> Number of faces: 0 Number of centroids: 0
> Number of kernels: 0 Map is 3D:
> 1 Number of dblinks: 1
> The associated table got element like those one:
> id | cat | id | igds_layer | eq_lvls | altitude
> 1 1 0 .... 5 100m
> (the value of the cl)
> Doing a query on the vector map i noticed this anywhere:
> map: 'cdl25m'
> mapset: 'PERMANENT'
> feature type: Line
> length: 4008.907401
> Line height: 0.000000 <== Is this ok with 3d file?
Maybe it is 3D but all the objects have 0 elevation?... Can you
verify that the z coordinate of your shapefile is other than 0 in some
other program? Then we could blame Grass (or OGR).
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
