[GRASSLIST:10543] Re: Labels and ps.map
Michael Barton
michael.barton at asu.edu
Fri Feb 24 02:18:35 EST 2006
Nick,
I see that you are talking about the display labels created by
d.vect--rather than those created by d.labels.
The d.vect labels are a 'quick and dirty' vector labeler, but that is
exactly what is needed at times.
I just did a test with the new gis.m and attach 3 small files here. In two
cases (making the eps and pdf), I used the print function dialog. In the
third case (making a png), I used the save output function.
As you can see, there are labels in all 3 images.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Nick Cahill <ndcahill at facstaff.wisc.edu>
> Date: Fri, 24 Feb 2006 07:34:35 +0200
> To: Multiple recipients of list <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:10541] Re: Labels and ps.map
> Dear Michael,
> In d.m and gis.m, there is a radio button for showing labels, you
> choose what column to display and its parameters, left, right, size,
> etc. Does this make a temorary label file for display? I was guessing
> that it was somehow able to draw directly from the database, since
> there is no place to specify a label file. This all seems very
> intuitive; but when printed to postscript, those labels do not appear
> (for me at least; because I don't have ghostscript, perhaps?). So
> I've been working through ps.map; which works fine, but involves the
> extra step of creating a label file. The postscript from ps.map comes
> out as proper editable text, not as a raster, which is important to
> me as I'll need to move the labels around later. Creating the label
> file is not much of a hassle, except that it requires knowing in
> advance how large the labels should be; you can't resize them on the
> fly and immediately see what the results are. I just wondered whether
> a more direct method was in store for the future.
> Thanks,
> Nick
> On Feb 24, 2006, at 6:39 AM, Michael Barton wrote:
>> Nick,
>> Point vector attribute display in d.m and gis.m is done by
>> d.labels--with
>> original labels file prepared by v.label (or by hand).
>> There is a fair amount of control over the display possible.
>> However, the
>> labels ultimately are rendered to the screen as rasters. Gis.m can
>> output
>> the screen to EPS or a postscript device now (if you have ghostscript
>> installed). However, it is output as a postscript bitmap/raster
>> image. If
>> you make your map display larger, it might give you higher
>> resolution in the
>> final EPS.
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Tue, 21 Feb 2006 20:15:03 +0200
>>> To: GRASSLIST international <GRASSLIST at baylor.edu>
>>> Subject: [GRASSLIST:10492] Labels and ps.map
>>> Dear Grass Gurus,
>>> Is there a reason why d.m and gis.m can display point vector
>>> attributes as labels, but this can't be output to a postscript file;
>>> and ps.map has to rely on the - I assume, somewhat outdated - method
>>> of using a separate label file? Currently, to get labels to come out
>>> correctly in ps.map, I have to run ps.map, look at the postscript
>>> output, find that the labels are a bit too big or something, make a
>>> whole new label file with different parameters, and start again; and
>>> this usually takes a number of iterations. It would be much more
>>> convenient (for me at least, as a user) to have site labels be part
>>> of vector display within ps.map, so you could have e.g.
>>> vpoints vector
>>> type point or/and centroid
>>> layer # (layer number used with cats/where/sizecol options)
>>> cats list of categories (e.g. 1,3,5-7)
>>> where SQL where statement like: vlastnik = 'Cimrman'
>>> masked [y|n]
>>> color color
>>> fcolor color
>>> **attlabel (attribute column)
>>> **attlabelsize (in points or whatever)
>>> **font, color, etc.
>>> Or am I missing something obvious?
>>> Thank you,
>>> Nick Cahill
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060224/512dcba8/labeltest_eps.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060224/512dcba8/labeltest_gs.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060224/512dcba8/labeltest_png.obj
