[GRASSLIST:10594] Re: GRASS 6.1cvs gis.m error
Ing.Peter Misovic
peter.misovic at gmail.com
Sun Feb 26 15:37:26 EST 2006
Things are going to be complicated. As I wrote, I started gis.m from
directory with right permissions and it works fine. I liked to try
last gis.m from your site Michael. So I copied sources of v.what into
vector folder of Grass and started to configure and make Grass again
(if I understand it, I have to do that way) - to make newer version od
v.what. But :
Generating HTML manual pages index (help system)...
Generated HTML docs in ../dist.i686-pc-linux-gnu/docs/html/index.html
Following modules are missing the 'description.html' file in src code:
g.pnmcomp
GRASS GIS compilation log
Started compilation: Sun Feb 26 21:10:15 CET 2006
Errors in:
/home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_20/raster/r.le/r.le.setup
/home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_20/vector/v.what
Finished compilation: Sun Feb 26 21:27:04 CET 2006
(In case of errors please change into the directory with error and run 'make')
I tried to make it directly in v.what folder but :
[misovic at thailon v.what]$ make
gcc -I/home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_20/dist.i686-pc-linux-gnu/include
-O3 -mcpu=pentium4 -Wall -Wall -Wconversion -Wno-implicit-int
-I/usr/local/include -DPACKAGE=\""grassmods"\"
-o OBJ.i686-pc-linux-gnu/main.o -c main.c
`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
main.c:24:21: glocale.h: No such file or directory
main.c:25:17: gis.h: No such file or directory
main.c:27:18: Vect.h: No such file or directory
main.c:28:20: raster.h: No such file or directory
main.c:30:18: dbmi.h: No such file or directory
main.c:32:20: config.h: No such file or directory
main.c: In function `main':
main.c:40: error: storage size of 'window' isn't known
Please, would I stay with old v.what from
grass-6.1.cvs_src_snapshot_2006_02_20 in combination with news gis.m
and gm folder or is better to make it with untouched original source
of CVS Grass.
Thank you,
if it is just because of development I understand and I shall wait.
Peter
On 2/26/06, Ing.Peter Misovic <peter.misovic at gmail.com> wrote:
> Yes, I understand the concept. It works fine now. I've started Grass
> from folder with limited write permissions.
> I have question in regard of this issue. Is it problem to find out in
> script (code) from system WHO is starting script ? If it is not, the
> script could create temp (etc.) files directly into home directory of
> user who has started this script. Even if the sctipt is not starting
> from user's home directory.
> Peter
> On 2/26/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> > Ing.Peter Misovic wrote:
> > > I'd like to ask you for help with gis.m Grass manager. Manager is not
> > > starting properly 'cause it is crashing with following error :
> > > ERROR: PNG: couldn't open output file dispmon_1.ppm
> > The PNG driver is trying to save its files in the current directory.
> > If you don't have write permission on that directory, it will fail.
> > Similarly, if the file already exists but you don't have write
> > permission on it, it will fail.
> > ISTR that later versions of gis.m tell the PNG driver to put the files
> > in a temporary directory.
> > Either cd to a directory for which you have write permission, or
> > update to a more recent version of gis.m. In any event, you should do
> > the latter sooner rather than later, as gis.m is under active
> > development.
